3CX Phone Buttons Grey'd Out
Discussion in 'Windows' started by Nachomama, Aug 15, 2014.
  1. Nachomama
    Aug 15, 2014
    11
    On v12 SP6 using a Cisco SPA514G with latest template and 7.55 Firmware
    The Answer button on incomming call
    and Hold, transfer, mute speaker are all grey'd out while on an active call
    Any suggestions?
    10,375
    231
    Is this with a licensed version, Demo key applied.....?
  3. Nachomama
    Aug 15, 2014
    11
    Yes licensed version 16 concurrent call pro
      File size:
      14.1 KB
      1,857
  4. leejor
    10,375
    231
    Is this one extension, or a number, that are behaving in this manner?
    Is this a local or remote extension?
    If only one, have you looked over the 3CX logs during a set registration, to see if there are any errors?
    Did this work at one time, did something change, update?
  5. Nachomama
    Aug 15, 2014
    11
    They are all remote phones - just seems to be with the cisco phones we have a yealink that's not doing this, new version 12 install err upgrade from 11, nothing in the logs other than extension registered.
  6. 3CXNP
    3CX Support
    Apr 25, 2014
    42
    Hi Nachomama,
    CTI functionality on Cisco/Linksys phones is limited.
  7. Nachomama
    Aug 15, 2014
    11
    Ugg these are still supported phones.
    Does that mean you feel it's working as intended/as good as it's going to get?
  8. Nachomama
    Aug 15, 2014
    11
    I guess this is truly a SNOM / Yealink switch now.
    3CX has givin us no upgrade path from 11 to 12 with any other sets even though they were "Preferred" only a year ago.
  9. 3CXNP
    3CX Support
    Apr 25, 2014
    42
    This is a Cisco hardware limitation in SIP.
