- Joined
- Aug 4, 2015
- Messages
- 4
- Reaction score
- 0
Hi there!
I just installed 3CX 12.5 phone system. I have 4 extensions:
100 – Operator registered in a new Yealink SIP-T21P. Firmware on latest version 34.72.0.75.
Codec priority: PCMU | PCMA | G722 | G729.
301 – Jimmy registered in 3CX Phone Windows 8.1, also in 3CX iPhone version.
302 – Yorch registered in 3CX Phone Windows 8.1, also in 3CX iPhone version.
Codec priority: PCMU | PCMA | G722 (there's no G729 option).
303 – Isabel registered in 3CX Phone Windows 7.
Calls between iPhone | Windows work just perfect (any initiator).
Calls initiated from iPhone to Yealink also work fine.
Calls initiated from Yealink to Windows or iPhone work fine.
The only issue is when I try to call from Windows clients (any of 3) to Yealink phone. The phone never rings and call is directed to voicemail after a while.
3CX Service Packs/Updates says: up to date (in green, SP1 & 2). Checkboxes are disabled. License is free version (evaluating to buy commercial version).
Windows clients were provisioned automatically using the email configuration file.
Yealink phone was provisioned automatically using the 66 option in DHCP (plug-and-play option didn't work out-of-the-box).
Logs at Yealink phone just don't register the incoming call.
Logs at 3CX phone system say:
1) Failure from Windows phone:
04-Aug-2015 13:09:59.564 [CM503008]: Call(C:71): Call is terminated
04-Aug-2015 13:09:59.563 Leg L:71.1[Extn] is terminated: Cause: CANCEL from 192.168.10.96:49454
04-Aug-2015 13:09:47.641 [CM503025]: Call(C:71): Calling T:Extn:100@[Dev:sip:[email protected]:5062] for L:71.1[Extn]
04-Aug-2015 13:09:47.594 [CM503027]: Call(C:71): From: Extn:302 ("Jorge Ponce de Leon" <sip:[email protected]:5060>) to T:Extn:100@[Dev:sip:[email protected]:5062]
04-Aug-2015 13:09:47.594 [CM503004]: Call(C:71): Route 1: from L:71.1[Extn] to T:Extn:100@[Dev:sip:[email protected]:5062]
04-Aug-2015 13:09:47.592 [CM503001]: Call(C:71): Incoming call from Extn:302 to <sip:[email protected]:5060>
2) Success from iPhone App:
04-Aug-2015 13:11:57.935 Leg L:73.1[Extn] is terminated: Cause: BYE from PBX
04-Aug-2015 13:11:57.934 [CM503008]: Call(C:73): Call is terminated
04-Aug-2015 13:11:57.930 Leg L:73.2[Extn] is terminated: Cause: BYE from 192.168.10.110:5062
04-Aug-2015 13:11:54.200 [CM503007]: Call(C:73): Extn:100 has joined, contact <sip:[email protected]:5062>
04-Aug-2015 13:11:54.198 [CM503007]: Call(C:73): Extn:302 has joined, contact <sip:[email protected]:5077>
04-Aug-2015 13:11:54.196 L:73.2[Extn] has joined to L:73.1[Extn]
04-Aug-2015 13:11:51.811 [CM503025]: Call(C:73): Calling T:Extn:100@[Dev:sip:[email protected]:5062] for L:73.1[Extn]
04-Aug-2015 13:11:51.763 [CM503027]: Call(C:73): From: Extn:302 ("Jorge Ponce de Leon" <sip:[email protected]:5060>) to T:Extn:100@[Dev:sip:[email protected]:5062]
04-Aug-2015 13:11:51.763 [CM503004]: Call(C:73): Route 1: from L:73.1[Extn] to T:Extn:100@[Dev:sip:[email protected]:5062]
04-Aug-2015 13:11:51.761 [CM503001]: Call(C:73): Incoming call from Extn:302 to <sip:[email protected]:5060>
I've seen the same error different times at this support forum. I've checked the provided solutions but no one has worked for me.
Hope someone can help me. Thank you in advance!
