3CX Phone - Disable DND button
Discussion in 'Windows' started by sdavies68, Jun 23, 2015.
  1. sdavies68
    Jan 26, 2010
    21
    Is there any way to disable the DND button on the new 12.5 3CX Phone. While its a nice feature for typical users, its a very bad feature for call centre operators who are smart enough to see that can still be logged into the queue but not taking calls.
    Regards
    Stephen
  2. Thomas 3CX
    3CX Support
    May 6, 2015
    15
    Unfortunately there is no way to "disable" DND button from the 3CX Phone.
    Thanks.
  3. sdavies68
    Jan 26, 2010
    21
    OK, if there is no way to currently do this on 3CX can this be a feature added. This did not exist on the old 3CX MyPhone and now its in the new interface this is very bad for call centres.
  4. leejor
    11,084
    325
    You can submit feature suggestions here...
    http://www.3cx.com/ideas/index.php
  5. thatguycraig
    Aug 18, 2015
    6
    Im only very new to all things SIP and 3cx, and i know next to nothing about it whilst im still learning, however, just a thought...
    could you not rearrange the buttons on the phone to say something else? May have to be done via the phone manufactuer interface (i. we have Yealink phones, within 3cx you can launch the web front end, or just type in the ip to an explorer)
    i know in there you can change the softkeys, so maybe take off the DND button and replace it with something else? They can use the short cut (*60* or w.e it is) but for those who dont know that code... that should stop them?
    plus i think you can change the keypad short cuts anyway
    again, i know nothing on how to do most things in here, just a thought!
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    You are referring to a physical phone - this forum is for the 3cx Softphone (3cx Phone for Windows/Mac).
    The DND button is easily clicked and produces unintended results. I heard maybe it is gone in v14 though.
