3CX Phone - Doesn't hang up a call
Discussion in '3CX Phone System - General' started by adamwells, Jul 22, 2015.
  1. adamwells
    Mar 20, 2015
    25
    A couple of users are reporting that their 3CX Phone software continues to say they are on the phone, even though the call has hung up.
    This also happens if they transfer a call.
    Is anyone aware of this? We use a terminal services environment. Their phones are Yealink T46G.
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi Adam,
    How did you provision the 3CX Clients ? Furthermore are you getting any error messages when you are trying to end the call ?
    Regards
  3. adamwells
    Mar 20, 2015
    25
    I used the welcome email method (not aware of another way?)
