3CX Phone doesn't install
Discussion in 'Windows' started by AnKun, Mar 6, 2012.
  1. AnKun
    Feb 8, 2012
    Hi, when I run 3CXPhone6.msi, it says the following:
    The program is not installed on my system (it was long time ago, it was uninstalled then). To confirm this I ran "msiexec.exe" with /x key, and it said the program is not installed. Is there some leftover remain, or is it a bug?
    Is there a way to solve it? I'm attaching my process output just in case
    10,778
    286
    Did you come across this old post in your search of the forum?
    http://www.3cx.com/forums/problem-installing-3cx-voip-phone-on-windows-xp-19859.html#p102438
  3. AnKun
    Feb 8, 2012
    I tried some of the suggestions from that topic but nothing helped. For now on the affected machine I'm using X-lite to work with 3cx Phone System, but I would still be grateful for the solution without the need to reisntall OS.
