3CX Phone - dynamically assigned port number?
Discussion in '3CX Phone System - General' started by uwaver, Nov 20, 2013.
  1. uwaver
    Sep 11, 2013
    I have the following issue. Every time 3CX Phone connects to 3CX Phone System it gets a random port number (i.e. 1.2.3.4:51126). I cannot see an option to make it static. Due some restrictions, a Firewall cannot be setup as follows:
    Source: 3CXPhoneSystem:5060
    Destination: 3CXPhone:<random>
    ... and firewall should be setup as follows:
    Destination: 3CXPhone:<static>
    Could you give an suggestion how to make it work?
    Thank you.
    10,360
    226
    Admittedly, (on my current PC I'm using an older version 6), but, in the Preferences/General Network Settings/Local SIP Port, there is a tick box (Any) next to the port setting. If that is checked, then the port could vary, otherwise it should use the port that you choose.
    Later versions may have it slightly different, but should still allow you to set the local port.
    That said, I have seen some routers that do port substitution, so no mater what you start out with at the remote end doesn't mean that the same port number is what "reaches" 3CX.
    What make/Model routers are you using at each end? That (options) may be having an affect.
  3. uwaver
    Sep 11, 2013
    Hello leejor,
    Thank you for reply. Yes, this option is there. It works as expected. Thank you.
    Case closed.
