Re: 3CX phone for iPhone 3G-incomplete registration CallCent
OK- Was able to get it to register. Now cannot complete test calls (Rings busy both outgoing and incoming). They suggest turning off MULTITASK and NAT; leaving STUN server blank; inserting callcentric.com as Proxy; I also tried substituting 5062 for local SIP port; they also suggest trying other apps another softphone provider. I also tried uninstall/reinstall of app.
Here's an excerpt from recent support ticket:
18:45:47 Rx udp:72.92.97.30:5060
INVITE sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.100:5060;rport;branch=z9hG4bKPjJmGlgXyj9r7BCJd6HDk65WFlAGqLdLPb
Max-Forwards: 70
[email protected]>;tag=ImV9xj0sUg1q4nrWkZLtm.1T4AhumhAj
To: sip:
[email protected]
Contact: "TrainingAce" <sip:
[email protected]:5060>
Call-ID: wVNsO4j12JfgFidBXE1j06K4EB0.gnfg
CSeq: 20325 INVITE
Route: <sip:callcentric.com;lr>
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Supported: replaces, 100rel, timer, norefersub
Session-Expires: 1800
Min-SE: 90
User-Agent: 3CXPhone for iPhone 1.0.23
Proxy-Authorization: Digest username="17772525091", realm="callcentric.com", nonce="b90b6f2ed83f15bb
71130b43fc33e389", uri="sip:
[email protected]:5060", response="4577fcd57fe16012788cd7ca4
0e386f4", algorithm=MD5
Content-Type: application/sdp
Content-Length: 278
v=0
o=- 3517584346 3517584346 IN IP4 192.168.1.100
s=pjmedia
c=IN IP4 192.168.1.100
t=0 0
a=X-nat:0
m=audio 4000 RTP/AVP 0 8 101
a=rtcp:4001 IN IP4 192.168.1.100
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=sendrecv
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Your softphone is still sending the "loose routing" option. At this time, we suggest you contact 3CX for more information on how to disable loose routing.
As an alternative to the 3CX softphone, we recommend using either the iSip app (http://www.vnet-corp.com/iphone.htm) or Acrobits Softphone (http://www.acrobits.cz/products/acrobits-softphone/).
