3CX Phone for windows 10 mobile
Discussion in 'Windows' started by decorator, Feb 11, 2016.
  1. decorator
    Feb 11, 2016
    Hello!
    I have installed 3CX Phone for windows 10 mobile on my phone lumia 720. I introduced all settings of the ip-operator (not 3CX).
    But the application writes "No registration".
    I talked to tech support operator and found that the application tries to be registered with the wrong password.
    Operator's answer was:
    "We receive authorization attempts with an incorrect password.
    The application 3CXPhone for Windows10 14.0.44619.0 - with an incorrect password"
    So, the application sends the wrong password.
    Please help.
    Thanks.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    3CX Phone apps are unlikely to work and register against any other PBX or operator...
  3. decorator
    Feb 11, 2016
  4. NickD_3CX
    Jun 2, 2014
    1,379
    84
    I stand corrected!!!! :oops:
  5. decorator
    Feb 11, 2016
    This bug fix possible?
  6. NickD_3CX
    Jun 2, 2014
    1,379
    84
    Actually, it turns out it was the blog post that was mistaken, please check it again, it has been altered.
