3CX Phone for Windows 10
Discussion in 'Windows' started by vgtan, Aug 13, 2015.
  1. vgtan
    Aug 13, 2015
    Can somebody to help me to solve this problem, after install 3CXPhone, i get the error message :
    3CXPhone has encountered an unhandled exception and will close.
    Crash report file:
    C:\Users\Samer\AppData\Local\3CX VoIP Phone\Logs\2015_08_13_10_45_14.dmp
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Ensure all windows updates / .net updates are installed as a first step.
  3. vgtan
    Aug 13, 2015
    I check .NET updates, and I already have install .NET Fremework 4.5.
    What is the next step?
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Ensure you have the c++ 2010 runtimes installed aswell.
  5. vgtan
    Aug 13, 2015
    I have Windows 10 in my laptop, and this upgrade about 4 days, all updates is a new version. I don't have c++ 2010, but i have 2015.
    Is there a another solution except my updates.
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Please install the 2010 aswell as per documentation
  7. hammadrafique
    Sep 8, 2015
    Run it as an administrator, and also run it in Windows 8 compatibility Mode. To enable compatibility mode Go to properties>compatibility>windows 8.
