3CX Phone for Windows features question
Discussion in '3CX Phone System - General' started by architechture, Aug 15, 2013.
  1. architechture
    Apr 3, 2013
    8
    Will the new 3CX Phone for Windows have the ability to send a call to someone else voicemail? Not mine, someone elses. :)
    Right now it seems the receptionist has to use the phone keypad to forward someone to another voicemail. And the same for forwarding a call to someone elses cell phone.
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Cant you already do that with *4(extension number)
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    That's not the question..
    You may want to add/post at https://apps.facebook.com/threecxideas for such a feature request.
    Ideally you could perhaps use a key/drag combo like holding CTRL while dropping the call onto an extension.. or right-dropping (not on the Mac.. or the smartphone..).
