3CX Phone for Windows Provisioning
Discussion in 'Windows' started by pricosoft, May 13, 2015.
  1. pricosoft
    Nov 7, 2014
    As long as the "3CX Phone for Windows" cannot be provisioned we have developed a small tool to do this.
    Features:
    - Copy template configuration if not still existing
    - Applying provisioning XML file into the newly created configuration file (based on username)
    - Applying policy Settings in existing and new XML configuration file
    - Automatically starts the phone Software
    - Based on configuration, hides the phone window during start
    HowTo:
    I would prefer to place the program into a logon script of any user (e.g. User Configuration\Windows Settings\Scripts (Logon/Logoff).
    Before you begin you need to edit the configuration file ("PriCoSoft.PhoneStart.ini"; description inside).
    Legal:
    Copyright (c) 2015 PriCoSoft
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. USE IT AT YOUR OWN RISK.
