3CX Phone for windows V12 deployment via GPO
Discussion in 'Windows' started by danavni, Sep 21, 2013.
  1. danavni
    Dec 5, 2010
    16
    is it possible to deploy the 3CX Phone for windows V12 via GPO? where do i find instructions on how to do that?
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    The MSI deployed fine.
    For the config, I sent the welcome message after modifying part of the text to tell users to run the attachment to config the app.
    I do not see how I could "map" a user/computer and extension to autoprovision, so I don't think that would be possible or helpful. The only thing I could think of would be to take the config files and put them in a Startup folder.. but that seems more messy.
