3CX Phone MSI - Customize Options or set defaults?
Discussion in '3CX Phone System - General' started by sexy-trousers, Feb 18, 2015.
  1. sexy-trousers
    Feb 12, 2015
    9
    Is there any way to set some of the options for the 3CX Phone client (other than the basics listed in 3CX itself)? I want to set the default behavior for inbound calls and chats to pop up/grab focus, but I can't find any info how to do that.
    I will be deploying via GPO, so hoped I could edit the MSI or use the Advanced > Custom Parameters option to force a default as that setting seems to be help in the 3CXPhone.xml file. Even if there were a base/template of the 3CXPhone.xml file on the server I could edit would be ok...
    Has anyone out there already tried to do this?
    Thanks, TJ
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    No there isn't a way to deploy preconfigured accounts / xmls from 3cx phone system, nor a preconfigured xml storred on server.
    What one could do on the other hand is on first logon from AD users, run a logon batch that will copy or create the user XML dynamically.
