3CX phone not able to pickup voicemail on Switchvox
Discussion in 'Windows' started by PGaffney, Apr 15, 2010.
  1. PGaffney
    Apr 15, 2010
    Odd problem.
    Backend I'm currently using Switchvox from Digium as a PBX. I tried the 3CX soft phone (which I really like) and noticed that it was unable to pickup voicemail. Here's what happens:
    Start 3CX soft phone. Phone registers with server.
    Voicemail indicator comes on.
    Press button to call voicemail on server. Voicemail answers - "Password?"
    Enter password.
    System responds "incorrect password. Password?".
    1st time I think I've forgotten the password - so I go into the extension configuration and reset the voicemail password for the extension. On the 2nd try I get the same "incorrect password" response from the voicemail system. On the 3rd try I use an alternate IP softphone and get right in.
    Anyone else seen this behavior with Switchvox or an Asterisk based PBX?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Here is description of problem with asterisk - http://www.3cx.com/forums/dtmf-tone-is-not-submitted-correctly-including-log-13711.html
    You need to report this problem to Switchvox support.
