3CX Phone Not Connecting
Discussion in '3CX Phone System - General' started by KerryG, May 6, 2013.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Anyone else trying this out yet? I can't get the new 3CX Phone to connect using the configuration file.
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Me too, neither can switch modes.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    Check out the comments here... seems they are not quite there yet:
    http://www.3cx.com/blog/releases/3cx-phone-system-12-alpha/#comments
    On windows 8 - my config files were empty for some reason when I saved them. It was strange... when I saved ona win7 machine then opened from the win8 machine the config file had info...
    When I manually added an account on the soft phone it worked.
    But CTI mode was not working.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    inbuilt phone doesnt work for us either you seem to have to use CTI mode IP handsets, in addition you will have to use an older version of 3cx softphone with the new 3cxphone/myphone app.
  5. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    At the current stage to use 3CXPhone in CTI mode you need to have 3CXPhone AND a hard-phone configured at the same extension. please let me know if you have any more questions.
