3CX Phone on a Mac
Discussion in '3CX Phone System - General' started by jasonhayes, Dec 27, 2017.
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    9
    Hi. Does anyone know how to save the changes made in the Switchboard Settings window. I have unticked "Show Presence of" some groups, but each time I exit 3CX Phone Client, everything is ticked again, it doesn't remember the options I select or de-select.
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    I have not experienced this myself although I have not used the Mac client for some time now (since the feature set is far inferior to Windows or the Web Client).
    Check you are running Mac OS 10.10 or higher first and if not already try a removal of the client from the Mac reboot, re-installation and re-provision.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @jasonhayes
    What version of the client are you running so i can try and replicate? Are you on the latest PBX version?
  4. jasonhayes
    May 9, 2012
    140
    9
    Running macOS high Sierra V 10.13.2 and the 3CX V15.5 R2 Client 15.11.112. I have now installed the 3CX Phone Client on two Mac's (running the same versions above) and both have the same issue. Any options you select to turn off "Show Presence of" within "Switchboard settings" are lost when you exit the client and re-start it.
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    77
    Happy New Year! :)
    We managed to replicate this, thank you for bringing it to our attention. I will try to update you if and when it has been addressed.
  6. jasonhayes
    May 9, 2012
    140
    9
    Can I add one more bug?
    The order of Call History is a bit strange, doesn't appear in Date Order (see attached).
    Works fine in the Windows Client.
  7. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    Hi Jason
    Jason, what's the client version? I'm asking because we fixed the sorting order bug in Call History quite long time ago, and on our clients calls appears properly sorted.
    vali
  8. jasonhayes
    May 9, 2012
    140
    9
    Mac Client V 15.1.1.112. 3CX Itself V.15.5 R2
    Just checked my history today and as you will see below it is still showing out of order with calls from today mixed in with ones from December.
  9. Vali_3CX
    Dec 12, 2008
    1,479
    67
    Hmmm, it might be something similar with a bug we found recently on iOS:
    can you open please your MAC System Preferences / Language & Region and tell me the Region, Calendar and Time Format?
  10. jasonhayes
    May 9, 2012
    140
    9
  11. 100028
    Nov 6, 2017
    7
    Our customer had the same issue and was suddenly solved. Don't know if there was an update for Mac or 3CX Phone? Can you check both?
  12. jasonhayes
    May 9, 2012
    140
    9
    Nope. Still on the using the "All" view the dates are all mixed up.
