Vali_3cx, et al.,
I modified the config.ini file to start both logs, which were not there before. I restarted the Phone and here is the PhoneSIP log:
(9572)1000400|.\RTPSide.cpp(246):Unable to change priority of RTP receiver(audio) from '2147483647' to '0'
(9572)1000400|.\RTPSide.cpp(264):Unable to set affinity mask of RTP receiver(audio) to '3'
(9572)1000400|.\RTPSide.cpp(288):Unable to set ideal processor for RTP receiver(audio) to '32'
(9572)1000400|.\RTPSide.cpp(246):Unable to change priority of RTP receiver(control) from '2147483647' to '0'
(9572)1000400|.\RTPSide.cpp(264):Unable to set affinity mask of RTP receiver(control) to '3'
(9572)1000400|.\RTPSide.cpp(288):Unable to set ideal processor for RTP receiver(control) to '32'
(9572)4000400|.\RTPSide.cpp(253)
riority of RTP receiver(audio) has been set to '0'
(9572)4000400|.\RTPSide.cpp(271):Affinity mask of RTP receiver(audio) has been changed to '3'
(9572)4000400|.\RTPSide.cpp(295):Ideal processor for RTP receiver(audio) is set to '32'
riority of RTP receiver(control) has been set to '0'
(9572)4000400|.\RTPSide.cpp(271):Affinity mask of RTP receiver(control) has been changed to '3'
(9572)4000400|.\RTPSide.cpp(295):Ideal processor for RTP receiver(control) is set to '32'
(9572)4000400|.\RTPSide.cpp(467)
riority of RTP sender has been set to '0'
(9572)4000400|.\RTPSide.cpp(485):Affinity mask of RTP sender has been changed to '3'
(9572)4000400|.\RTPSide.cpp(509):Ideal processor for RTP sender is set to '32'
(9572)8000110|.\ssl\Security.cxx(867):BaseSecurity::BaseSecurity
(9572)8000108|.\dns\AresDns.cxx(141)
NS initialization: found 2 name servers
(9572)8000108|.\dns\AresDns.cxx(144): name server: 68.94.156.1
(9572)8000108|.\dns\AresDns.cxx(144): name server: 68.94.157.1
(9572)8000110|.\Compression.cxx(40):COMPRESSION SUPPORT NOT COMPILED IN
(9572)8000110|.\Compression.cxx(43):Compression configuration object created; algorithm = 0
(9572)8000110|.\TransportSelector.cxx(93):No compression library available
(9572)8000108|.\UdpTransport.cxx(42):Creating UDP transport host= port=51450 ipv4=1
(9572)8000110|.\InternalTransport.cxx(86):Creating fd=1524 V4/UDP
(9572)8000110|.\InternalTransport.cxx(94):Binding to 0.0.0.0
(9572)8000110|.\UdpTransport.cxx(60):No compression library available: Transport: [ V4 0.0.0.0:51450 UDP target domain=unspecified mFlowKey=1524 ]
(9572)8000110|.\TransportSelector.cxx(192):Adding transport: [ V4 0.0.0.0:51450 UDP target domain=unspecified mFlowKey=0 ]
(9572)8000110|.\ConnectionBase.cxx(49):ConnectionBase::ConnectionBase, who: [ V4 0.0.0.0:0 UNKNOWN_TRANSPORT target domain=unspecified mFlowKey=0 ] 072716F0
(9572)8000110|.\ConnectionBase.cxx(62):No compression library available: 072716F0
(9572)8000110|.\ConnectionManager.cxx(24):ConnectionManager::ConnectionManager() called
(9572)8000110|.\InternalTransport.cxx(86):Creating fd=1296 V4/TCP
(9572)8000108|.\TcpTransport.cxx(28):Creating TCP transport host= port=51450 ipv4=1
(9572)8000110|.\TransportSelector.cxx(192):Adding transport: [ V4 0.0.0.0:51450 TCP target domain=unspecified mFlowKey=0 ]
(9572)8000110|.\ConnectionBase.cxx(49):ConnectionBase::ConnectionBase, who: [ V4 0.0.0.0:0 UNKNOWN_TRANSPORT target domain=unspecified mFlowKey=0 ] 07274698
(9572)8000110|.\ConnectionBase.cxx(62):No compression library available: 07274698
(9572)8000110|.\InternalTransport.cxx(86):Creating fd=1320 V4/TCP
(9572)8000108|.\ssl\TlsTransport.cxx(40):Creating TLS transport for domain interface= port=51451
(9572)8000108|.\UdpTransport.cxx(42):Creating UDP transport host= port=51452 ipv4=1
(9572)8000110|.\InternalTransport.cxx(86):Creating fd=1156 V4/UDP
(9572)8000110|.\UdpTransport.cxx(60):No compression library available: Transport: [ V4 0.0.0.0:51452 UDP target domain=unspecified mFlowKey=1156 ]
(9572)8000110|.\TransportSelector.cxx(192):Adding transport: [ V4 0.0.0.0:51452 UDP target domain=unspecified mFlowKey=0 ]
(9572)8000110|.\ConnectionBase.cxx(49):ConnectionBase::ConnectionBase, who: [ V4 0.0.0.0:0 UNKNOWN_TRANSPORT target domain=unspecified mFlowKey=0 ] 07270E50
(9572)8000110|.\ConnectionBase.cxx(62):No compression library available: 07270E50
(9572)8000110|.\InternalTransport.cxx(86):Creating fd=1752 V4/TCP
(9572)8000108|.\TcpTransport.cxx(28):Creating TCP transport host= port=51452 ipv4=1
(9572)8000110|.\TransportSelector.cxx(192):Adding transport: [ V4 0.0.0.0:51452 TCP target domain=unspecified mFlowKey=0 ]
(9572)8000110|.\UserProfile.cxx(135):Adding credential: realm=3CXPhone user=15
(10096)8000108|.\TuSelector.cxx(70):Stats message
(10096)2000104|.\StatisticsMessage.cxx(152):RESIP:TRANSACTION
TU summary: 0 TRANSPORT 0 TRANSACTION 0 CLIENTTX 0 SERVERTX 0 TIMERS 0
Transaction summary: reqi 0 reqo 0 rspi 0 rspo 0
Details: INVi 0/S0/F0 INVo 0/S0/F0 ACKi 0 ACKo 0 BYEi 0/S0/F0 BYEo 0/S0/F0 CANi 0/S0/F0 CANo 0/S0/F0 MSGi 0/S0/F0 MSGo 0/S0/F0 OPTi 0/S0/F0 OPTo 0/S0/F0 REGi 0/S0/F0 REGo 0/S0/F0 PUBi 0/S0/F0 PUBo 0/S0/F0 SUBi 0/S0/F0 SUBo 0/S0/F0 NOTi 0/S0/F0 NOTo 0/S0/F0
Retransmissions: INVx 0 BYEx 0 CANx 0 MSGx 0 OPTx 0 REGx 0 finx 0 nonx 0 PUBx 0 SUBx 0 NOTx 0
(9568)8000108|.\TuSelector.cxx(70):Stats message
(9568)2000104|.\StatisticsMessage.cxx(152):RESIP:TRANSACTION
(9572)8000110|.\SipStack.cxx(90):SipStack::~SipStack()
(9572)8000110|.\ssl\Security.cxx(915):BaseSecurity::~BaseSecurity
(9572)8000110|.\TcpBaseTransport.cxx(74):Shutting down [ V4 0.0.0.0:51452 TCP target domain=unspecified mFlowKey=0 ]
(9572)8000110|.\ConnectionBase.cxx(89):ConnectionBase::~ConnectionBase 07270E50
(9572)8000108|.\UdpTransport.cxx(66):Shutting down [ V4 0.0.0.0:51452 UDP target domain=unspecified mFlowKey=1156 ]
Here is the Tunnel Log:
09:42:44:483 - Info : Logger started-------------------------------------------------------------------------
09:42:47:248 - Trace : Local address has been specified as NULL or 0.0.0.0, choosed as best one 192.168.5.10
09:42:47:259 - Trace : Iface info read: idx=0x0000000B; ip=192.168.5.10; mask=0xFFFFFF00
09:42:47:259 - Trace : Iface info read: idx=0x00000014; ip=169.254.2.2; mask=0xFFFFFF00
09:42:47:259 - Trace : Iface info read: idx=0x00000001; ip=127.0.0.1; mask=0xFF000000
09:42:47:286 - Info : Tunnel is now listening for SIP calls on 51449 for bridge 123456 [123456]
09:42:47:289 - Info : Attempting to connect remote tunnel 123456 [64.249.253.209:5090]
09:43:08:288 - Warning : Connection failed, next attempt in 430 msec
09:43:08:388 - Info : Connection thread stopped
09:43:08:507 - Info : Tunnel 123456 with ID=123456 has been now shut down------------------------------------------------------
09:43:11:357 - Trace : Local address has been specified as NULL or 0.0.0.0, choosed as best one 192.168.5.10
09:43:11:366 - Trace : Iface info read: idx=0x0000000B; ip=192.168.5.10; mask=0xFFFFFF00
09:43:11:367 - Trace : Iface info read: idx=0x00000014; ip=169.254.2.2; mask=0xFFFFFF00
09:43:11:367 - Trace : Iface info read: idx=0x00000001; ip=127.0.0.1; mask=0xFF000000
09:43:11:388 - Info : Tunnel is now listening for SIP calls on 51452 for bridge 123456 [123456]
09:43:11:395 - Info : Attempting to connect remote tunnel 123456 [64.249.253.209:5090]
09:43:32:388 - Warning : Connection failed, next attempt in 430 msec
09:43:32:489 - Info : Attempting to connect remote tunnel 123456 [64.249.253.209:5090]
09:43:53:493 - Warning : Connection failed, next attempt in 3526 msec
09:43:53:593 - Info : Attempting to connect remote tunnel 123456 [64.249.253.209:5090]
09:44:14:601 - Warning : Connection failed, next attempt in 1462 msec
09:44:14:702 - Info : Attempting to connect remote tunnel 123456 [64.249.253.209:5090]
