3CX Phone runs in background with no GUI
Discussion in 'Windows' started by GDavid, Jun 2, 2015.
  1. GDavid
    Mar 16, 2015
    9
    Any ideas on how to troubleshoot this would be greatly appreciated.
    The 3CXWin8Phone.exe runs in Processes, but there is no GUI and nothing in the Taskbar. Can't see it during alt-tab (ruling out the 'off screen' theory)
    The install was previously working and must have stopped (the user isn't sure when) in the last couple of days. Windows 7 Pro, non-domain. Original installation over a month ago had no issues and registered easily. There is only one user on this PC.
    Have tried:
    Uninstall and re-install 4 times.
    Uninstalled, deleted the 3CX folders in Appdata and Program Files, also tried running ccleaner on the registry after uninstall.
    AND rebooted. Several times.
    disabled antivirus and removed programs installed in the last few days.
    getting a little frustrating.
    thanks,
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    I started a ticket.. as been escalated twice thus far.
    Best at current is a workaround.. Run as Administrator is working.
    Certainly annoying!
    Might still be user profile, but I ruled that out last round.
  3. GDavid
    Mar 16, 2015
    9
    Thanks Ian, appreciate your help. I could try a different profile. Currently this user is set up as a local admin, but I can activate the administrator account and test on there if you think it would be helpful.
  4. andrea.soc
    Feb 24, 2016
    39
    7
    i have the same problem with a Tablet with windows 10 , the client is 14 version.
    Stay in the taskbar but if click on application, don't return in gui ..
    thanks
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    When you first run the application does the client load normally? Is this happening only when you minimise the app? I would try the new V15 client and see if that is working for you
  6. Sal
    Sal
    May 12, 2017
    5
    I have the same problem. Just installed V15 on a Windows 10 machine. The client stays on the taskbar but I'm unable to maximize it. I'm able to make calls from the webclient so it does appear to be working.
    sal
  7. V..
    V..
    Feb 14, 2017
    74
    29
    Hi Sal,
    I have encountered a bug where the client goes offscreen when maximized. Try mousing over the 3CX icon in the taskbar, right clicking the 3CX phone window and clicking 'move' then use the arrow keys left or right to move the client back into view.
  8. Sal
    Sal
    May 12, 2017
    5
    V, that actually worked. Thanks
    V.. likes this.
