3CX Phone stops working in Windows 10
Discussion in 'Windows' started by voip26, Aug 3, 2015.
  1. voip26
    Jul 17, 2015
    For all of you considering moving to Windows 10 - don't. Not yet anyways.
    I've had the upgrade from Windows 8.1 to 10 and my 3CX Client immediately stopped working and will not load.
    It throws up the following error on attempting to load:
    Start(): Unable to start 3CXPhone API Host
    One or more errors occurred.
    Inner Exception:
    System.ServiceModel.AddressAccessDeniedException: HTTP could not register URL http://+:8085/. Your process does not have access rights to this namespace (see http://go.microsoft.com/fwlink/?LinkId=70353 for details). ---> System.Net.HttpListenerException: Access is denied
    at System.Net.HttpListener.AddAllPrefixes()
    at System.Net.HttpListener.Start()
    at System.ServiceModel.Channels.SharedHttpTransportManager.OnOpen()
    --- End of inner exception stack trace ---
    at System.Runtime.AsyncResult.End[TAsyncResult](IAsyncResult result)
    at System.ServiceModel.Channels.CommunicationObject.EndOpen(IAsyncResult result)
    at System.Web.Http.SelfHost.HttpSelfHostServer.OpenListenerComplete(IAsyncResult result)
    Stack Trace:
    at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
    at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Windows 10 is not supported yet, please refer to the supported OS list from the admin manual / chapter 2.
    That being said wondering if you edited the error message with fqdn / port number in the previous snippet ?
  3. livn46
    Oct 24, 2014
    77
    Some of the guys on our IT team upgraded to Windows 10 and 3CXPhone continued to work after the upgrade, with no problems reported yet. So it does work in at least some circumstances.
  4. voip26
    Jul 17, 2015
    @pj3cx - no, didn't edit the FQDN / Port number in the snippet.
    @livn46 - that's interesting... it's what I expected to happen since the Windows 10 pre-upgrade checks showed no issues at all. What version of the 3CX client are they running?
  5. livn46
    Oct 24, 2014
    77
    It was 12.5.44288.0. I know of at least one who upgraded Windows 10 in-place and it continued to work after upgrading, and at least one who did a clean install, instead, of Windows, and then installed 3CXPhone, and he also said he had no trouble.
    I think what pj3cx is alluding to is that "HTTP could not register URL http://+:8085/" seems not right; should have a server name or an IP address there, so the problem might be with your configuration: maybe try a new provisioning file or something? Or uninstall/delete config directory/re-install?
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    3cx for Windows works fine when I upgraded to Win 10 on bootcamp.
  7. luzbayona
    Aug 7, 2015
    Well any news on when Windows 10 will be supported? Because my program also stopped working.
  8. andreaschr
    Oct 26, 2015
    91
    6
    Hi luzbayona,
    Windows 10 is supported from 3CX Phone System V14 and above . We are using windows 10 with 3CX Phone Client and PBX without any issues :)
