3CX Phone system 10 - Outlook 2013
Discussion in '3CX Phone System - General' started by Stef - Venema Advies, Aug 4, 2014.
  1. Stef - Venema Advies
    Apr 10, 2012
    26
    We have a issue with a customer that is using 3CX phone system 10 and Outlook 2013.
    When i install 3CX Myphone and 3CX outlook plugin it wont work.
    The Outlook plugin keeps chrasing. :cry:
    Is there a solution for 3CX phone system 10 and Outlook 2013 to work toghether so you can make a call out of your Outlook 2013 contacts?
    Kind regards,
    Venema Advies BV
    Stef Hoogervorst
    http://venema-advies.nl
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    789
    45
    Hi Stef,
    Have you read the article http://www.3cx.com/blog/docs/troubleshooting-outlook-crm/
    This is for Troubleshooting plugin errors in Outlook 2010, not for 2013 but maybe it is useful.
    As far as I know v10 does not support 2013.
  3. Stef - Venema Advies
    Apr 10, 2012
    26
    Using Outlook 2013 is not gonna work with 3CX Phone sytem 10.
    Need to upgrade 3CX phone system to version 12 to solve this problem. :evil:
  4. jasit
    jasit New Member
    Feb 12, 2013
    171
    check out teletrigger
  5. Stef - Venema Advies
    Apr 10, 2012
    26
    Teletrigger is a good solution! Thanks Jasit! :lol: :D
