3cx phone system 12.0
Discussion in 'Windows' started by jc2516, Sep 14, 2015.
  1. jc2516
    Sep 14, 2015
    I am using a Windows7 32bit system. I tried the 3cx phone system v12.0 and it worked on my system. Now 3cx.com doesn't provide v12.0 any more. I just want to know where I can download the v12.0.
    Thanks.
  2. 12494
    12494 Member
    Apr 16, 2010
    298
    29
    I used google and searched download 3cx version 12 and found this link -
    http://downloads.3cx.com/downloads/3CXPhoneSystem12.exe
    3CX only supports the current and 1 prior versions which would be v14 and v12.5. I would recommend you upgrade your system. Of course if you are running 32 bit Windows you will need to upgrade to 64 bit Windows - this should be a free upgrade.
    Regards,
    Allen
  3. jc2516
    Sep 14, 2015
    Thank you.
