3CX Phone System Email Notification - ID 12294 - Error respo
Discussion in '3CX Phone System - General' started by JakeTSP, Jun 7, 2015.
  1. JakeTSP
    Jun 7, 2015
    Hi Guys,
    I always see this error and i'm struggling to find the root cause, It has not been a problem, its just an eyesore to receive this every now and again on a blue moon... any advice how to get rid of it would be appreciated -
    issue:[​IMG]
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Re: 3CX Phone System Email Notification - ID 12294 - Error r
    Meh, I've seen them from time to time.. doesn't seem to be anything big I've heard of.
    I suppose it comes down to the trunk provider.. who is returning this 404.
    Usually, though, I just shrug that one off.
  3. positron
    Jan 14, 2013
    76
    11
    It means the destination number was invalid. Equivalent to hearing a recording saying "the number you have dialed has been disconnected or is no longer in service".
    Usually is either a misdial or someone was given an incorrect phone number.
  4. JakeTSP
    Jun 7, 2015
    ah, I see - thanks for that! it makes sense,
