3CX Phone System for Windows with MS Outlook 2013
Discussion in '3CX Phone System - General' started by abitec, May 15, 2013.
  1. abitec
    Nov 6, 2012
    11
    Support the new version also MS Outlook 2013, or only maximally 2010 ?
    Thanks Jaro
  2. mlump
    mlump New Member
    Feb 24, 2012
    113
    I have V11 SP4 and am having no difficulty with the outlook addin running on Outlook 2013.
  3. abitec
    Nov 6, 2012
    11
    I have also V11, but how you use MS Outlook add in ? - How you configure add-in with MS OU 2013 ?
    In the MS OU 2010 I have possibility configure add-in, but when I have OU 2013, I cannot in 3cx configure any connection with this.
    Jaro
  4. mlump
    mlump New Member
    Feb 24, 2012
    113
    Sorry i should have said desktop components instead of Outlook addin. The desktop components includes a COM+ addin for outlook. You should just need to install the desktop components and make sure MyPhone is up and running when you try and call from Outlook. I should note all of my testing has been on 32bit installations of Office 2013 i have not tried it on a 64bit installation of office 2013.
  5. mlump
    mlump New Member
    Feb 24, 2012
    113
    Are you still having trouble with this?
  6. kristijonas
    Jan 29, 2013
    27
    works fine with 64 bit as well
