3CX phone system install error
Discussion in '3CX Phone System - General' started by ZacNet, Aug 27, 2008.
  1. ZacNet
    Aug 27, 2008
    I suppose you Vista users have heard of the 2755 error code when trying to install 3CX phone system, and don't know how to fix it. Well, right now I'm encounterin it and hope one of you XP or under users can help me fix it. I'm encounterin the following error message when trying to install it:
    3CX phone system setup has encountered an unexpected error when installing 3CX Phone System, this may indicate a problem with the package. the error code is 2755.
    is there a way to fix it? or doesn't 3CX want Vista users installing they're products?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Please ensure you are using Windows Vista Business, as specified in http://www.3cx.com/support/operating-systems.html
    regards
