3CX Phone System not recording calls?
Discussion in '3CX Phone System - General' started by creativemiles, May 31, 2017.
  1. creativemiles
    May 31, 2017
    Hello
    We use your 3CX Phone System, recently shifted from windows to linux as this is much better for resources, however I've noticed that although ticked the system is not actually recording calls on the linux version, does anyone have a solution?
  2. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Have you checked the record from extension as well?
  3. creativemiles
    May 31, 2017
    Hello, Thanks for the reply. - Yes this is the first thing I had checked.
  4. Razva
    May 7, 2017
    32
    Are you using the free version? If yes...it doesn't supports call recording and you should grab a license.
  5. creativemiles
    May 31, 2017
    Yes I am, the windows version was also free, this did record calls.
  6. Razva
    May 7, 2017
    32
    Maybe you are talking about an older version (pre v15)? In v15 call recording is not offered for free (for my disappointment as well). Check the Feature Comparison page, you'll see that "Call Recording" is only available for the Standard+ licenses. :oops:
    So you may want to stick with an older version if free + call recording is important. I myself paid for the Standard license and called it a day.
  7. creativemiles
    May 31, 2017
    I see yes, I'm willing to bet the windows version was (pre v15). - Thanks.
  8. futures
    Jun 19, 2009
    8
    Have the same problem.. upgraded from v12.5 to 15 and can not get call recording to work.
    This is very important to my company
    thanks
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,352
    535
    @futures
    Make sure that you are not using the free version as recordings are not available in the free version. Also check that you have not exceeded your quota. You can find this under recordings / Quota in the management console.
