3cx Phone System over Point-to-point link
Discussion in '3CX Phone System - General' started by asoetadji, Apr 9, 2014.
  1. asoetadji
    Apr 9, 2014
    Hi guys I'm new in here just started using the 3cx phone system free version for a week or so.
    Testing it out over the 2 offices that we have. The 2 offices are connected over a point to point wireless link using ubiquiti radios. They are configured in bridge mode. Essentially these two offices are in the same LAN and subnet.
    3cx phone system is installed on a server using windows 2008r2 and has an IP address of 192.168.60.77
    All PCs are able to connect and get an "available" status and be on hook. The people within the same plant can call and speak normally. However when they are trying to call someone else on the opposite plant they are unable to connect and it would go to voicemail.
    Please help me out.
    Thanks in advanced!
    Andre
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    The bridge was not intended to be used on the same network segment.
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,154
    178
    @bardissi
    I think you misread his question. 3CX is not in bridge mode, the ubiquiti radios are bridging the two locations.
    @asoetadji
    You mention the IP address of the server, but not of the PCs that are working/not working. Also, since you mention PCs, I'm assuming there using soft phones. Can you confirm the PBX version (assuming v12sp4) and the soft phone version, and whether or not the soft phones at the plant that isn't working are registered?
  4. leejor
    10,848
    299
    Check the 3CX server log after one of these failed calls. There should be some clues as to why the set was not reachable. Did the destination set show as registered at the time of the call? What, in your network architecture would cause the IP to be unreachable?
    Can you ping a PC (running the softphone) from a PC in the opposite plant, if not, why not?
  5. engin411
    engin411 New Member
    Jul 3, 2009
    172
    FYI, our entire 3CX system (20 extensions, 8 call paths, 2 SIP trunks) is on a Ubiquiti PTP link. Works fine.
