3cx phone system v.10 beta2 test
Discussion in '3CX Phone System - General' started by cda, Apr 19, 2011.
  1. cda
    cda
    Nov 30, 2009
    1.the problem is that, we know that externel connexion is disabled by default, but we can not anable, because the checked button is locked, How we can unlocked it?
    2.After installing 3cx system v.10 beta 2 in windows server 2008 64bits, if we need to add users , a new windows appear with a warning "WEBGUI Interface has stopped working" and the system is closed. This an error or a planing situation?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    1. Are you using a license key or did you not enter a license key yet?
    2. It is working fine on my 2008 Server 64bit, did you choose IIS or Abyss as the web server?
