3CX Phone System v.10 support VOIP Gateway PLANET VGW-400FO?
Discussion in '3CX Phone System - General' started by tubakibetun, Jun 2, 2014.
  1. tubakibetun
    May 8, 2014
    Dear All Master,
    I want to buy a VOIP Gateway, it brand PLANET VGW-400FO.
    like this bellow:
    http://www.planet.com.tw/en/product/product.php?id=48477#appl
    for use on 3CX PhoneSystem v.10
    whether 3CX PhoneSystem v.10, support the VOIP Gateway?
    Thank you.
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Re: 3CX Phone System v.10 support VOIP Gateway PLANET VGW-40
    No look at Patton, or Grandstream.
