3cx phone system v 12 tunnel problem
Discussion in '3CX Phone System - General' started by egec-xprt, Jul 8, 2014.
  1. egec-xprt
    Jul 8, 2014
    i was had 3cx phone system v 8 and it is work good with tunnel for external 3cx phone client but after i install v 12 i face big problem in tunnel , when i connect external 3cx soft phone client it is not connect and i got this error from tunnel log
    ConnMgr.cpp(393) : [12:15:47.986](Critical0):Tunnel connection authentication failed! Passwords mismatch. Requested by 41.196.182.235:29237 identifying as '3cx.egec-xprt.com'(123456)
    TCPSide.cpp(117) : [12:15:49.006](Log2):Connection destroyed (master side) on socket 668; num.conn=0
    TCPSide.cpp(105) : [12:15:49.006](Log2):Connection created (master side) on socket 668; num.conn=1
    and i type tunnel password good and no way.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there, if you will connect remotely to an extension with/without tunnel, ensure that in its properties / Options tab / "Disallow use of extension outside the LAN" is unticked, otherwise you will get such password errors.
