3CX Phone System V15 on Linux - Deleted my recordings without permission
Discussion in '3CX Phone System - General' started by cduquev, Nov 18, 2016.
  1. cduquev
    Nov 18, 2016
    3cx deleted without my permission the recordings, without these fulfilling the 120 days that was configured. Please check that I consider it a very serious mistake.
    Is it possible to recover the deleted recordings in Debian Linux?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello there,
    If you have the ability to open a support ticket either directly or through a partner please do as we need to investigate your issue as we have not heard anything similar before.
  3. Norbert
    Dec 19, 2016
    We have experienced the same issue with the v15 SP4 on Debian after migrating from Windows. No issue before migrating but since migrating recordings are deleted even though setting is specified for 30 day delete.
  4. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Did you migrate from a previous version backup which contained recordings? Were the recordings there and then deleted or were they deleted from the beginning?
  5. Norbert
    Dec 19, 2016
    There were recordings in the import from previous. They also have been deleted. New recordings are stored and then deleted within a day.
    Maybe the clean up cron is hours and not days?
  6. YiannisH_3CX
    May 10, 2016
    7,358
    535
    I have sent you a P.M
