3CX Phone System V5.1 - RC - build 4128
Discussion in '3CX Phone System - General' started by aguilar, Feb 14, 2008.
  1. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    i am trying to install the altest version 3CX Phone System V5.1 - RC - build 4128,
    I made a backup
    uninstall previous version
    reboot
    and when i install get a message that a previous version was found and stops
    any help will be appreciated
    regards
  2. scu
    scu
    Jan 26, 2008
    19
    Hi Aguilar,
    Do you have 3cx installed in a server or xp? If you have it in a server, go to services and stop all the services of 3cx before uninstalling 3cx. Try to reboot and run setup again. I have it installed in Win 2003 Server and I didn't have a problem installing this version.
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello Scu
    thanks for the answer, i have it running in a vista box and before unistall i stoped all services and reboot but now something remains because the installer find a previos one and stops
  4. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    yes, it was deleted
    rgds
  5. ra81
    Oct 24, 2007
    8
    This is happening because uninstallation ended prematurely.
    Delete the registry key "Build" from HKEY_LOCAL_MACHINE\SOFTWARE\3CX\PhoneSystem and you can install the latest version of 3CX Phone System.
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    thanks a lot Robert, worked just fine
    cheers
  7. addinsol
    Jan 5, 2009
    I have the same problem but I could not install 6.0 on Windows Small Business Server 2008 properly. Now it keeps saying the software is there. I removed the folder and the key. Any suggestions.
