3CX Phone System
Discussion in '3CX Phone System - General' started by snhlawy, Aug 20, 2014.
  1. snhlawy
    Aug 20, 2014
    Does 3CX Phone system have a recording option to record calls between agents and clients to monitor performance.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Yes you can record the calls of an agent, by going in his extension settings / Options tab / tick Record all calls.
    Then you can listen those from web reports depending on your rights.
  3. snhlawy
    Aug 20, 2014
    when i purchase the 3CX phone system Pro package which is for 1210 USD is it once in a life time or i have to renew the license on yearly bases.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    For these questions, you could contact your regional sales representative by looking at the map on this link you'll find the numbers:
    http://www.3cx.com/company/contact/
