abehar said:Thanks for your answer.
Actually we don't need pstn lines or connect to a voip carrier, we just want to use the pbx for internal extensions (around 100) and we want to be sure we're using an adequate hardware for it.
We've been testing the product with good results and we want to jump into production mode.
Also if you can recommend a sip phone ithat you know works good it would be appreciated.
Thanks.
Angel Behar
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
