3CX phone systems with PHP
Discussion in '3CX Phone System - General' started by frobak, Dec 3, 2014.
  1. frobak
    Dec 3, 2014
    Is it possible to integrate 3cX systems with a PHP applications
    Specifically, when the phone rings, i need to grab the caller id/number, get that into PHP, and then process it within the application.
    Is there any documentation on this sort of thing?
    Do you even think this is possible?
  2. jasit
    jasit New Member
    Feb 12, 2013
    172
    check if your phones have action url, when you say get into php, I am assuming you need to send something to a webserver.
    the yealink phones do, just not sure about yours.
    jasit
  3. frobak
    Dec 3, 2014
    Hi Yes, the phones are Yealink T46GN, is there any documentation, tutorials that you're aware of?
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,553
    300
    I found it was easier with the 3cx Phone for Windows to launch an external application when the phone rang.
    I could not find a way to get the inbound caller id on the device.
  5. jasit
    jasit New Member
    Feb 12, 2013
    172
    K, a quick google and a quick test,
    here is some of the settings.
    so on the phone, under Action URL Incoming Call
    http://ipaddress of webserver/somefile.php?device=$mac&local=$local&remote=$remote&displayremote=$display_remote
    then make a phone call to that extension, and after you hang up go check the log files on the webserver, you should see the following
    2014-12-03 22:11:57 192.168.0.99 GET /somefile.php device=00:15:65:3e:5a:de&local=sip:2254%40192.168.0.90&remote=sip:2045551212%40192.168.0.90&displayremote=2045551212 80 - 192.168.0.199 Yealink+SIP-T38G++38.70.1.26+00:15:65:3e:5a - 404 0 2 0
    I found this http://www.sustworks.com/pa_guide/genericNotification.html
  6. frobak
    Dec 3, 2014
    Brilliant, thanks for your help. I'll be testing this over the next few days so will report how I get on.
