3cx phone terminal server problem
Discussion in 'Windows' started by Tubbs, May 18, 2015.
  1. Tubbs
    May 18, 2015
    I have just upgraded the our server from 11 to 12.5 and wanted to use the new 3cx phone on our terminal servers for our users aswell.
    i installed the 3cx phone on my test server and when i open the welcome mail with .3cxconfig under my admin account all goes well. When i than log in with a user account and open that .3cxconfig the program wants to open the 3CXPhoneforWindows125.msi again and install again. If i allow this in the applocker than it even asks to reboot the server again. And even allows the user to do this.
    However when i save the .3cxconfig to the desktop, and drag the config on the running program the config does get loaded.
    So my question is? why does double clicking on the .3cxconfig file starts the whole installation again for each new user. The program is already installed it should only load some settings.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    763
    39
    I think you are running into privilege issues.
    Please try the following steps:
    Login as admin and uninstall 3CXPhone completely
    Reboot the machine if necessary
    Login as user and run 3CXPhone as Administrator (right click .msi file)
    Double click .3cxconfig to provisioning 3CXPhone
    Hope this help
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Note that MSI packages do not provide the "Run as Administrator" context menu item as an executable file does.. though there are some reg hacks to create a similar action.
