3CX Phone Transfer function
Discussion in '3CX Phone System - General' started by enzop, Jun 27, 2007.
  1. enzop
    Jun 27, 2007
    8
    According to the specs the 3CX Phone should have a transfer function:
    Call transfer (ECT)
    I do not mean forward or conference, just plain transfer: I get a call, put it in hold, call another extension and transfer. Or even "blind transfer: I get a call and i transfer it straight away to another extension.
    However, I have not been able to understand how this can be done.
    We have an Asterisk based server...
    Could somebody give me a clue, please?
    Thanks and regards,
    Enzo
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Our specs are for 3CX PBX, not 3CX Phone. 3CX PBX supports blind, attended and consultation transfers.
  3. enzop
    Jun 27, 2007
    8
    Thanks Archie,
    Does it means that the softphone doesn't provide this function and I should eventually get it from the PBX? Asterisk in my specific case or by the 3CX Phone system?
    Anybody knows how this could be done?
    Thanks again,
    Enzo
  4. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    i have little experience with asterisk, cept it beeing a headache for me.
    Ive replaced the asterisk of a client of mine (constant compains bout voice quality etc) and put in a 3cx pbx. no more complains about voice quality. also stuff as call forwarding and transfer work perfectly.
    I would say, format the asterisk server and install 3cx.
  5. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello Enzo, are you trying to use 3CX phone with Asterisk?
    3CX phone is a free tool provided by the 3CX team.It is meant for testing purposes with 3CX phone system. At the moment the phone does not do transfer. There is a new version (v2) in the works of the phone which will be available around Q3 of 2007 and it will support transfer as well as other features that (v1) of 3CX phone doesn't support at the moment.
    I love the way you think Dakhalli :D
