3CX Phone using CallTo Protocol
Discussion in 'Windows' started by corys, Apr 13, 2015.
  1. corys
    Apr 13, 2015
    5
    I was wondering if anyone has figured out a way to associate 3CX Phone with the Call To: Protocol. I followed the instructions here http://www.3cx.com/blog/voip-howto/tel-protocol-3cxphone/for the tel protocol and it works great, but the call to protocol does not work.
    Any advice is greatly appreciated.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    3CXPhone only associates with the TEL protocol not the CALLTO.
    Kindly post this as a feature request on 3CX Ideas : http://www.3cx.com/ideas
