3cx Phone V 14.0.57. Can't an an account
Discussion in 'Android' started by haywardi, May 23, 2016.
  1. haywardi
    Feb 27, 2011
    83
    Just factory reset my phone and now can't add an account into 3CX for Android...
    I go to setting, Accounts, but when the account screen appears it just says accounts at the top and no + button or 'Add' button appear.
    Thought I would send myself a Welcome email, but when I click on the attachment it says "I don't have an app that can open the attachment".
    I'm running Android 5.1.1 on a Note 4
    Advise greatly appreciated.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    I assume that since you have performed a factory reset on your device you have downloaded the latest 3cx client from the play store. If that is the case try downloading the attachment that is included in the welcome email and try to re open it. If it still doesn't work then download a file explorer from the play store, ( i personally use ES file explorer) and navigate to where you saved the attachment of the welcome email. Click on it and it should give you the option to choose a program to open it with.
    Choose the 3CX app and it should work.
