3CX Phone V12 bring to front option missing
Discussion in 'Windows' started by sohc, Feb 21, 2014.
  1. sohc
    Apr 22, 2009
    24
    Hi all,
    I'm new here in this forum. I recently implemented 3CX 16SC Pro as a replacement to my old NEC PABX. We are using Yealink T46G handsets.
    I installed the latest version of 3CX Windows V12.0.33517.0. Everything is working fine on CTI mode but when there's an incoming call it won't show the actual scree. I have to click on the tab.
    How can I setup the bring to front option? I saw a guide on this website but it is for V11.
    Appreciate any response.
  2. AndreasA_3cx
    Jun 2, 2014
    19
    Hello there an thank you for contacting us.
    Kindly try the option to Steal Focus under the Settings >> Advanced >> Behavior.
    Kind Regards
