3CX phone V12 -- debug window?
Discussion in 'Windows' started by Lukas, Dec 6, 2013.
  1. Lukas
    Jan 23, 2011
    45
    Hi! I have been searching for the debug window in the new version of the 3CX phone -- has it been removed?
    Also, we used to have the "barge in" functionality -- has that been removed as well?
    Thanks!
  2. mlump
    mlump New Member
    Feb 24, 2012
    113
    Lukas, i don't think there are any Debug options built into the new 3CXPhone as of yet however there is a log file you could look at here %userprofile%\AppData\Roaming\3CXPhone for Windows\Logs
    Barge in is available in 3CX v12, you have to have the new 3CX Pro licenses and you have to grant your users rights through the new group rights.
