3CX Phone version 12, why no web api through tunneling?
Discussion in 'Windows' started by Powermage, Jan 27, 2014.
  1. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    We use the 3cx tunnel function quite a lot and we liked it, no NAT troubles, just an tunnel and voip is working, i think one of the best key functions for specific customers.
    but since v12 we get the annoying error that the web API is not available.
    We are not planning to open-up the web-api port at the moment, we dont need it and we dont trust the security implementation we see about it, we are fine with the port closed (We dont need provisioning of remote stun extensions or somthing) but it would be nice if the web-api traffic was redirected through the already existing tunnel.
  2. coltex
    Oct 9, 2013
    I agree, we would like that as well, I've firewalled the current access to the web api port mostly, but that's suboptimal
