3CX phone voice too soft
Discussion in 'Windows' started by zhangjx99, Jul 22, 2010.
  1. zhangjx99
    May 26, 2010
    51
    Hi all, any one faced similar issue where softphone side can't hear otherside clearly due to the voice too soft, even put max volumn. other side (IP phone) can hear voice clearly from 3CXphone. any parameter can adjust? SKYPE on the same PC no such issue.
    Thanks. JX
  2. NickViz
    Aug 3, 2010
    I'm having similar problem: the 3CX phone loudness is very low. I tested it on some machines in 2 offices (so, connection was local and over the Inet) - in some cases the call was just quiet, but in some I can barely hear other party. And Skype in the same conditions worked without any problems.
    Is there any setting I can change in 3CXphone to setup loudness level / recording level? It's very nice application, but if it doesn't make well the main function - it's useless.
    Thanks in advance,
    Nikolai.
  3. carolinainnovative
    May 4, 2009
    369
    6
    This is very odd, because I often find I have the opposite problem - 3cxPhone is much louder than Bria on my system and often have to turn it down.
  4. NickViz
    Aug 3, 2010
    I guess it's related with PC hardware / drivers (mic boost etc.) What makes me unhappy that Skype could perfectly utilize any hardware we used and for 3CXphone it's far from true...
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Interesting, there is a setting to up the volume o the 3cx phone (prefernces) Im not sure if you have allready played with this setting, What sound card are you using?
  6. zhangjx99
    May 26, 2010
    51
    I am using default Mic and Speaker per attached, I also tried to use Microsoft Primary Mic/Speaker, but same result.
    where is the setting to up the volume?
    "there is a setting to up the volume o the 3cx phone (prefernces)"
    Thank you for your help.
    JX
  7. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    As far as I understand, both of you are referring about setting microphone level from 3CXphone interface, comparing with Skype. The answer is no, 3CXphone doesn't provide microphone level adjustment, since recording - unlike playing - is a global, per machine setting.
    Both Skype and Xlite change recording level on the global mixer (computer). Open a Skype, set the microphone level, then open an Xlite - it will mess Skype's setting. Adjust Skype's one, and Xlite will be messed. Open the global mixer and adjust from there - both Skype and Xlite will be messed.
    Therefore, being a global, per-machine setting, 3CXPhone doesn't want to alter it in any way.
  8. jcasares
    Dec 5, 2009
    92
    My issue was with hearing the others (too soft). This worked better with the last version I think.
    I really don't know why the change as I thought that was related to the audio drivers. :p
  9. Vali_3CX
    Dec 12, 2008
    1,476
    67
    I have to explain something to be clear and to avoid confusion
    3CXPhone's sound levels - those from preferences - affects only, let's say, phone's audio players. They don't affect computer's mixer volume.
    Now, my XP's audio mixer (which opens from speaker icon next to clock on taskbar) has two related sliders: master volume and Wave volume - these two should be checked. If they are too low, definitely you will get a low volume, even 3CXPhone's are set to max. Obviously, the mute checkboxes affect also.
    Hope it helps.
    Regards
    vali
  10. jcasares
    Dec 5, 2009
    92
    Today I checked using it to call between 2 3CX Phone and it was useless. I couldn't hear the other side properly and the other side couldn't hear me as well. When I maxed out microphone level he barely heard me but it was unacceptable. Lucky that at work I use it to call real phones and not 3CX Phone extensions because I would have to ditch it.
    Running on XP and with Skype it works wonderfully (the microphone and settings).
