3CX Phone (win) Import Contacts from Google Contacts CSV
Discussion in 'Windows' started by tiburonjames, Aug 30, 2011.
  1. tiburonjames
    Jul 14, 2011
    Thank you for your post, I tested it and it worked for me!
  2. tiburonjames
    Jul 14, 2011
    Yes, you have to change the output to xxxxxxxxxx format. In my case, I need an extra digit for Venezuela's telephone numbers (11 digits). Maybe, you could put some parameters in your page in order to generate the files (i.e. format telephone number, first digit for dial tone, etc.)
