3CX Phone - Windows - Call History Display bug
Discussion in 'Windows' started by TotallyVoIP, Oct 11, 2013.
  1. TotallyVoIP
    Jul 2, 2010
    77
    On V6.0.26523.0 of the Windows 3CX Phone (this was running on XP in 32bit mode)
    The call history pop up displays the wrong summary of call duration (in fact it swaps the times from Dialed and Answered) in the second drop down menu. The counts seem to be correct under each, it's just the times get swapped!
    Hopefully something simple to fix in the next release?
    thanks
