3CX Phone Windows - Portable conf?
Discussion in 'Windows' started by icane, Jul 23, 2012.
  1. icane
    Jul 23, 2012
    Hello, I need the configuration of 3CXPhone for Windows be the same for all users on the same computer without having to set each time. Anyone know a way to do this?
    thank you very much
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    I am uncertain what it is you are trying to achieve. If the same for all users on the same computer, then what configuration are you trying to change?
    What you could possibly do is to create multiple accounts on the softphone and manage that way. I assume that you only really want to configure for different names and extensions. Whoever uses will have to remember to go in and enable their account and disable the others.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You will have to create multiple user accounts and whenever someone changes into that seat they will have to log out of the account to login to theirs. Could you give an example on why there will be multiple users on one soft phone, that would help to give a more concise answer.
  4. karli1
    Jun 24, 2011
    Do you have a Windows-Domain with Active Directory in place?
