3CX Phone
Discussion in '3CX Phone System - General' started by MPC9, Nov 19, 2012.
  1. MPC9
    Nov 19, 2012
    We have an issue with the 3CX phone which disconnects after 1m 10 secs on internal calls only about 50% of the time. Has anyone else experienced this please?
  2. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    Need more information.
    Are you talking about the 3cx pbx (this forum) or the 3cx softphone for windows (the next forum down)?
    Can you post some logs? This isnt normal so appears to be a problem with your setup.
    Is it more than one extension?
  3. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Also can you start wireshark on that computer where is 3cx phone or on the server side to see which side disconnect the call?
