3CX phonebook capacity
Discussion in '3CX Phone System - General' started by plunket, Jul 8, 2010.
  1. plunket
    Jun 16, 2010
    7
    i just have to know one thing: how many contacts i can store in the 3cx phonebook?
    I'a m using the current version (8) of 3cx.
    Thanks.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    There isnt a limit really, you can add away.
