Solved 3CX Phonebook not updating
Discussion in '3CX Phone System - General' started by tadrosr, Feb 12, 2018.
  1. tadrosr
    Dec 1, 2017
    11
    I have a t46s running on the latest supported software for 15.5. The phone is configured via RPS and works with no issues. But the 3cx phonebook is not populating.
    I've tried reprovisioning several times, but phonebook wont update or populate. I've also verified the link on the phone GUI settings and it does pull the xml file if I browse to it in a browser.
    #1 tadrosr, Feb 12, 2018
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    Guessing as you have setup the phones using RPS these are remote phones.
    Make sure firewall ports are open - https://www.3cx.com/docs/manual/firewall-router-configuration/
    Log onto the phone GUI (password is under extension - phone provisioning tab -> Phone Web Page Password), under Directory - Remote Phone Book you will see the url the phone will get the address book from, may sure the url / ip points to the correct location and the port is open on the firewall.
  3. tadrosr
    Dec 1, 2017
    11
    Hi @Saqqara - It was actually the certificate issue. But thanks for the added tip.
    Cheers
    phonemaster likes this.
