3CX Phonebook
Discussion in '3CX Phone System - General' started by mjenner701, Dec 6, 2011.
  1. mjenner701
    Dec 6, 2011
    I am using Yealink phones. They all connect and are able to display the 3CX Phonebook, however this phonebook is not searchable. Is there a way to make this phonebook searchable on the phones? Or is there a way to automatically add the 3CX contacts to the contacts on each phone?
  2. haywardi
    Feb 27, 2011
    84
    Can't answer your question directly, but have you tried myphone? If you download it to your pc, you can then search the phone book and place the call to your handset by a simple click!
    Iain
  3. smokeman
    Dec 10, 2010
    50
    i'm looking at ldap phonebook for this exact reason...it's just about unusable.
