3CX PhoneSystem 01 System Server will not start
Discussion in '3CX Phone System - General' started by TA Stewart, Oct 24, 2017.
  1. TA Stewart
    Jan 12, 2017
    10
    I cannot access the web management console and when the service tries to start on windows, the error is : error 193: 0xc1.
    3CX PhoneSystem 01 System Server and 3CX PhoneSystem 01 Management Console will not start.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Hello @TA Stewart
    Can you please let us know which version of windows you are using? Also when did the issue start? Was it working before? Did anything change before the issue occurred? Have you checked the windows event viewer to see if any relevant errors appear there?
  3. ivank
    3CX Support
    Jan 4, 2017
    54
    6
    Windows error 193 - "is not a valid Win32 application". Most probably, the file is damaged by some means.
  4. TA Stewart
    Jan 12, 2017
    10
    Windows 10 PRO.
    Services- 3CX PhoneSystem 01 Management Console and 3CX PhoneSystem 01 System Server will not start.
    Windows System Even Viewer reports:
    The 3CX PhoneSystem 01 Management Console service failed to start due to the following error:
    3CX PhoneSystem 01 Management Console is not a valid Win32 application.
    The 3CX PhoneSystem 01 System Server service failed to start due to the following error:
    3CX PhoneSystem 01 System Server is not a valid Win32 application.
    I was running the latest version of 3CX. The phones connect but I cannot connect to the web admin.
    Thanks!
  5. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Are you running Windows 10 Pro 32 or 64bits?
    All operating system must be install in its x64 version. 32 bit versions are not compatible with 3CX PBX server.
  6. TA Stewart
    Jan 12, 2017
    10
    Yes, it's all x64.
  7. complex1
    Jan 25, 2010
    814
    49
    Please check if Windows is up-to-date and please consider a re-install of 3CX.
    Are you running the Windows 10 Fall Creators Update?
